Normally i use layout #3 (dirtree left upper, preview pane left lower; thumbs listview on the right side).
If i change the language, eg. from <autodetect> to english, and restart,
the preview pane is away and replaced by the file file properties pane.
I need to reattivate manually view layout #3.
If i switch the language back to <autodetect>, i see only one single pane
appearing on the left side, where the dirtree covers a small portion of it
(a sub area, the remaining space of this left pane is empty),
Win7 x64, MP 0.82 beta 4.
Layout #3 lost when changing the language
klaus2
Re: Layout #3 lost when changing the language
Problem still there with 0.85 beta 2 (x64)
Reproduced with 0.85 beta 2.
Reproduced
seems to be fixed in lastest version
klaus2
Unfortunately not Pierre -it persists with 0.86
could you post a screenshot before and after, please?klaus2 wrote:Unfortunately not Pierre -it persists with 0.86
klaus2
Attached the screenshots before and after changing the language (from autodetect to english) using MP 0.86.
You will see that the contents of the left pane got corrupted after restart.
klaus2
The problem persists with 0.87 (win x64)
are you able to reproduce on 0.90?
