Opening System folders doesn't work
ovo201
How to open system folder (e.g. My Documents) and manage with files and folders in it with XnView browser?
Re: System folders
On the root of folder tree, you have desktop, Documents, ...
ovo201
Re: System folders
Thanks but it doesn't work, that's why I have posted this topic. I've tried with settings. Still have a problem.
Re: System folders
what's happened if you click on 'my document'?
ovo201
Re: System folders
Nothing, put me back to Desktop. When I go to User - My Documents, it can be opened but the other folders and files in it can't be opened and managed with.
- Forum Librarian
Re: System folders
Welcome to the forum, ovo201 (-:
Do you get the same behavior regardless of whether Show Desktop in folder tree (Tools » Options... » Browser » Folder tree) is activated or not?
ovo201
Re: System folders
Yes, I mentioned before I've tried with settings, just like you described it.
ovo201
Re: System folders
I just installed a XnViewMP and a system folder and folders in it are available now. I think I resolved a problem. Thanks for your concern. Kind regards.
