0.81 X64: Corrupt non-ASCII comment.
butty
Post by butty »
I'm using XnViewMP 0.81 x64. Found a problem in EXIF text handling.
Problem: When non-ASCII text is set to image comment, XnViewMP cannot show it correctly.
Steps:
1. Set a Japanese comment to an image with some image manipulating tool, such as XnView.
-> When viewing the thumbnail of the image with XnView, the comment is ok.
2. View the thumbnail of the image with XnViewMP.
-> The comment is shown incorrectly.
PS. Other properties, such as IPTC Object Name is ok.
XnView:
XnViewMP:
Regards.
Re: [XnViewMP] Corrupt non-ASCII comment.
could you send me a file sample?
butty
Post by butty »
Hi, here is the URL of the sample image with Japanese comment: http://piulento.net/tmp/XnViewMP/IMG_0331.JPG
the problem is that JPEG comment use current locale, so there is no way to know which encoding is used
butty
Post by butty »
Thanks.
I consider using other fields, such as EXIF user comment or IPTC's one.
But, I wonder why XnView and other apps are ok.
