Nag screen popup after installation
Octopuss
Could you remove internet browser opening automatically after the installation or at least give us the option to disable that via some parameters? This thing interferes with my unattended Windows installation.
Octopuss
Re: Nag screen popup after installation
Can you remove this "feature" please (or add an option for the installer to suppress showing it)? Personally, if I decide to donate to the project, I will do so on my own will and no nagging or popups will affect it.
ok
i'll add an option...
