Hi everyone,
I am unable to access to images in the folder with the Latin title (For example with characters š,đ,č,ć,ž). I hope you know solution for this!
Thank you.
Disabled access to images in the folder with the Latin title
Bayberry
Re: Disabled access to images in the folder with the Latin t
XnView Classic doesn't support Unicode, but you should be able to use XnView MP...Bayberry wrote:Hi everyone,
Bayberry
Ok, I installed XnView MP and now I am able to open all images. But I have other problem with this version, image opening is slower than with classic version. XnView classic opens image instant but with XnView MP I have about 1 sec delay, is that possible to speed up in any way?
Bayberry
Seems I checked some of option and got slow open, after reset to default it's ok.
Bayberry wrote:Seems I checked some of option and got slow open, after reset to default it's ok.
Possibly slow on first use due to creation of the database??
Bayberry
Maybe this, I really don't know but it works well now.cday wrote:Bayberry wrote:Possibly slow on first use due to creation of the database??
Also I noticed that images in higher resolution open for a bit slower than images in low resolution. So, maybe I entered in album with extremely high resolution at first.
