MP 0.81 (Mac): Crashing on closing tab
dustball
Post by dustball »
I'm browsing my folders and opening an image. I can browse through them, but when I try to close a tab, XnViewMP instantly crashes. The version is 0.81.
Re: (Mac) Crashing on closing tab
and if you open an image, and quit, always a crash?
dustball
Post by dustball »
Yes. It doesn't even matter if I open an image, it crashes when I close the main gallery tab as well (without opening any images).
dustball wrote:Yes. It doesn't even matter if I open an image, it crashes when I close the main gallery tab as well (without opening any images).
In the folder do you have only image files? JPEG?
dustball
Post by dustball »
I just tried a folder that has nothing but a single jpg in it, not even hidden files. It still crashes.
dustball wrote:I just tried a folder that has nothing but a single jpg in it, not even hidden files. It still crashes.
could you try the 0.82?
dustball
Post by dustball »
The issue persists with 0.82.
Is there something like strace for mac that I could do to give you more insight?
could you try to rename ~/.xnviewmp/xnview.ini?
dustball
Post by dustball »
Yeah, that did the trick. Thanks :)
dustball wrote:Yeah, that did the trick. Thanks :)
could you send me the xnview.ini?
dustball
Post by dustball »
Uh... not anymore, sorry. I'll see if I can recreate the problem and send it to you when I manage to.
dustball
Post by dustball »
Managed to break it again. Here's the ini: https://ptpb.pw/Ac36
For the sake of privacy, I removed the paths in "history", "pathbrowser" and "recentfiles". The crash is still reproducible without them.
with this xnview.ini, you go to a folder (with XnView) with only a jpeg file, open it, and close the tab by clicking on X icon, and crash?
dustball
Post by dustball »
That is correct.
I can't reproduce, same thing with a png file?
