Hi
I'm a long time user of XnView. I'm trying to prepare an old laptop (Windows 98 SE) with my favourite software, and I've found that the latest version of XnView won't install because my OS is not compatible. I don't know if that's a problem with the installer or if XnView doesn't work at all on Windows 98.
Does anybody knows what was the last version that supported Windows 98?
Thanks in advance.
Latest version to run in Windows 98?
Re: Latest version to run in Windows 98?
XnView v2.13 is the last version that work on Windows 95/98
Zup
Thanks for your help, I'll install it ASAP
