XnViewMP v0.81 x64
By default the "Fit image to window" is set on.
The button can not be set 'off'' (no toggle)
I tried setting view to 1:1 but the next file I open, is again set to fit image to window.
How to:
a. have XnView show images 1:1
b. be able to toggle between 1:1 and Fit to window
Thanks!
Fit image to window - issue
mrwul
- Forum Librarian
Re: Fit image to window - issue
Hi again, mrwul. Please update to v0.82 which has just been released.
mrwul
Okay, done. Now what?
So, I double click a .png file, it starts fit to image (toggle not possible)
I set tot 1:1
click on -> next - again mode is set to fit to image (not 1:1)
where are the settings about this fit to image?
I set tot 1:1
Isn't the problem that this setting isn't persistent?
I think this is part of a more general problem in 'MP, that some settings that might be expected to be persistent are not...
mrwul
probably I'll need to remove the line
fit=2
from the xnview.ini in order to get this fixed
but I should not hit the 'Fit to Window' button on my toolbar as it will add the line again and
it seems to stay there. only manual removal may 'reset' things...
that said, it is just a 'wild guess' - i am not sure about this though.
fit=2
