Displaying a thumbnail does not work (ASP)
Billy
Post by Billy »
Hi to everybody, my name is billy and i want to ask u something... I'm an asp person and recently i installed this component to work with asp, but unfortunelly, i couldn't find in the help area an example with vbscript (for asp) and it's making me nervious... can somebody help me giving me an example how to do a simple thumbnail from an image?? thanks and let me know, i found this, but it shows an error where is SERVER MAPPATH, it says that i'm selecting an invalid type of image... thanks for your help, masters!
Dim Image
Set Image = Server.CreateObject("GflAx" & gflsdk_version & ".GflAx")
Image.LoadBitmap server.mappath("/images_gallery/encabezado2.gif")
iwidth = image.width
iheight = image.height
= iheight/iwidth
if (image.width > int(request("width"))) then
newwidth = request("width")
newheight = request("width") * aspect
Image.Resize newwidth, newheight
end if
						Image.SaveFormat = 1 ' This is a JPEG
						Image.SaveJPEGQuality = 95
						Response.ContentType = "image/" & ctype
						Response.Expires = 60
						Response.BinaryWrite Image.SendBinary
Set Image = nothing
Ithier
Post by Ithier »
I don't know your about server.mappath problem, but as you are reading a gif file you must enable LZW compression before reading the file (because there is a patent from UNISYS on LZW, so it is not activated by default):
Image.EnableLZW = TRUE
Ithier wrote:I don't know your about server.mappath problem, but as you are reading a gif file you must enable LZW compression before reading the file (because there is a patent from UNISYS on LZW, so it is not activated by default):
Yes, i'll remove soon EnableLZW because the patent doesn't exists anymore...
