I used to use Xnview under Windows a long time ago. Now using XnView MP under OSX. I can only view the image preview on the Info pane, all other options Histogram, EXIF,......,GPS are ticked but will not display. Thanks in advance for any advice.
TwickersJohn
OSX: Can't display tabs on Info Pane
- Forum Librarian
Re: Can't display tabs on Info Pane under OSX
Welcome to the forum, TwickersJohn.
Please activate Preview as tab and Use tabs in View » Info pane.
BTW: You may want to consider adding buttons (Tools » Settings... » Interface » ToolBar) for the following commands to the toolbar of Browse mode:
- cmd_thumbsView
- cmd_treeShow
- cmd_infoView
- cmd_showPreview
could you post a screenshot?
