Show Categories under thumbnail
krieck
Post by krieck »
Is there any way to do this? I tried putting {Categories} in the custom field of the thumbnail labels options but to no avail.
Re: Show Categories under thumbnail
Could you please give IPTC: Keywords and/or IPTC: Categories (Tools » Settings... » Thumbnail » Labels) a try?
krieck
Post by krieck »
I ´ve tried but neither one worked.
Are the keywords and categories embedded in the IPTC metadata of your files (see samples @ iptc.org & embeddedmetadata.org)?
krieck
Post by krieck »
Ok, I´ve tested it with the samples and the ITPC keywords are shown. However I have videos categorized using the xnview DB too.
It seems as if the metadata has to be written to the files (Tools » Settings... » Metadata » IPTC & XMP » Keywords » Export DB Category to XMP Subject and IPTC Keyword) for the labels {IPTC:Keywords} + {IPTC:Category} to work.
@Pierre: Can you confirm this?
{Categories} is not supported for label on thumbnails
krieck
Post by krieck »
Ok, thanks for the help
