0.82 Linux: Not showing hdr thumbs on Linux
mzigaib
Post by mzigaib »
I am using Cent OS 7 and XnView is not showing thumbs for hdr files, any tips?
Re: Linux: Not showing hdr thumbs on Linux
mzigaib wrote:I am using Cent OS 7 and XnView is not showing thumbs for hdr files, any tips?
Thank you for your request, mzigaib.
- Which version of XnView MP do you use?
- Which camera/program did generate these file? Does viewing these hdr files work with XnView MP on Windows?
Related topic:
- Does XnView support graphic format .xyz?
mzigaib
Post by mzigaib »
Hi!
I am using the "Version 0.82 x64 (Sep 12 2016)" for Linux and the hdr files are downloaded from the internet like the ones on the hdrlabs site "http://www.hdrlabs.com/gallery/index.html".
In windows thumbs for hdr works fine I also had it working in Fedora but in Cento OS it seems something is missing.
mzigaib wrote: I am using the "Version 0.82 x64 (Sep 12 2016)" for Linux and the hdr files are downloaded from the internet like the ones on the hdrlabs site "http://www.hdrlabs.com/gallery/index.html".
i don't see a button to download hdr sample images?
mzigaib
Re: 0.82 Linux: Not showing hdr thumbs on Linux
Post by mzigaib »
ok, right i confirm
mzigaib
Post by mzigaib »
The weird thing is it was working on my first install since I changed computers and had to install again that happened.
