Redimensionando imagenes // resizing images
famp
Post by famp »
Como puedo redimensionar varias imagenes que estan en horizontal por ejemplo 800*600 y otra en vertical que esta en 600*800 en pixeles, y redimensionar por ejemplo a 700*500, no quiero mantener la relación de aspecto, pero si deben de mantener todas el mismo tamaño incluido las verticales, es posible introducir un relleno a las imagenes verticales para que tambien tengan 700*500.
Lo que quiero decir imagen vertical mas el relleno = imagen en horizontal.
Gracias a todos.
automatic translation yet
As I can resize several images that are horizontally for example 800 * 600 and another vertical, That this is 600 * 800 pixels, and resize for example 700 * 500, I do not want to keep the aspect ratio, but they must keep Including all the same size vertical, you can enter the UN filling vertical images to have also 700 * 500.
I mean more vertical image Filling = image horizontally.
Thank you all.
Re: Redimensionando imagenes // resizing images
you would like to have the same height for all pictures landscape and portrait?
famp
Post by famp »
si, pero sin deformar la imagen.
yes, but without distorting the image
in resize action, enable 'follow orientation' and enter 0 as width, and 500 as height
famp
Post by famp »
Funciona pero la imagen se gira algunos grados.
works but the image is rotated a few degrees
famp wrote: works but the image is rotated a few degrees
??? Could you post a sample
famp
Post by famp »
imagenes originales y transformada
original and transformed images
https://mega.nz/#F!Wc8kUSoQ
clave
key
!CtJfpu7Ga4TItgaQNlUkvw
and you have no rotate action???
famp
Post by famp »
no no tengo rotacion aplicada, hay otras imagenes que no salen giradas.
I have no unapplied rotation, there are other images that do not appear rotated.
could you post a screenshot of actions used
famp
Post by famp »
Tenia solo redimensionar.
He had only resize.
creo haberlo solucionado, he aplicado limpiar metadato, marcado las 6 opciones y no me gira las imagenes.
He ido desmarcando cada una de las opciones para saber cual era la culpable y mi sorpresa es que ya no me las gira.
Muchas Gracias
I think I've solved, I have applied to clean metadata, marking the 6 options and would not rotate images.
I went unchecking each of the options to see which was my fault and my surprise is that me not tour anymore.
Thank you very much
famp
Post by famp »
Hola de nuevo, no termino de ajustar bien las imagenes, yo necesito unas dimensiones de 870*420, si algun lado es menos debe ser relleno con un fondo, esto no consigo realizarlo con exito ya que el tamaño no es exacto a 870*240.
Hello again, I do not quite fit well the images, I need a size of 870 * 420, if somewhere is due less to be filled with a background, it does not get do it successfully because the size is not accurate to 870 * 240 .
famp
Post by famp »
Conseguido, ademas de los ajustes anteriores he incorporado un filtro lienzo de una tamaño de 870 * 420 y el color adecuado.
Muchas gracias, gran programa felicidades.
Achieved, besides the above settings I have incorporated a canvas filter of a size of 870 * 420 and the right color.
Thank you very much, congratulations great software.
