0.82: remembers opened files
2Gjv1VgGK
Post by 2Gjv1VgGK »
Hi. To reproduce the problem adjust settings that I highlighted. Open image from Windows Explorer, close XnViewMP by app's close button, open another image - now you can see two tabs with images in the viewer, but there must be only last one. Every time XnViewMP was closed by app's close button it remembers all opened files, if image was closed by tab's close button, then it works as expected.
2Gjv1VgGK
Re: 0.82: remembers opened files
Post by 2Gjv1VgGK »
Thank you, version 0.83 works fine.
