Hiding raw files
obelisk
Hiding raw files
How can I not show the raw files as thumbs, not load it to thumb cache? maybe even hide it from list
Re: Hiding raw files
In Settings > Filelist > Custom Filter. There you can set for file types whether these are displayed at all, displayed as thumbnails, or a preview is shown. Use "Exclude" and "Include" to exclude or include specific (custom) file types.
obelisk
I added raw ext to 'include' and unticked thumbnail
still shows as thumbnail
your files have .raw extension?obelisk wrote:I added raw ext to 'include' and unticked thumbnail
you have added "cr2, nef, dng, pef" in extension field?obelisk wrote:cr2, nef, dng, pef
obelisk
This way
or in exclude
all showing.
or in exclude
all showing.
obelisk
surely you can easily repro it.
custom filter
thumbnails
custom filter
thumbnails
why you don't add raw in exclude filter?
obelisk
Because I want to see it as icon.
Makes no difference.
ALways shows wherever I put it.
Ok, currently doesn't work if the extension is recognized as image...obelisk wrote:Because I want to see it as icon.
This is the same bug as in topic how to control which file types to browse: The user-defined file settings have no priority over other settings. This means that for images and other file types inclusion/exclusion cannot be used at all.xnview wrote:Ok, currently doesn't work if the extension is recognized as image...obelisk wrote:Because I want to see it as icon.
