Add auto playing sound file on batch completion
pangwolin
Post by pangwolin »
Would be nice to have the option to automatically play a custom sound file once a batch has completed.
Mock-up example:
Please consider it. :)
pangwolin
Re: Add auto playing sound file on batch completion
Post by pangwolin »
On second thought, if you don't want to bother including sound libraries (understandably) here is an even better idea:
Add a "run custom command". That way, users can invoke their own scripts through the shell, including playing a sound file with "paplay" on Linux for example. :D
