Am i the only one with this problem? File Can't be loaded
mindscape8088
Post by mindscape8088 »
I have had XnView almost a year and recently got an error every time i went to use it . "file can't be loaded " The first time i disconnected all my external drives which fixed it . But now for no reason it gives me this error every time now. So essentially i no can no longer use the program. Am i the only one ? cannot find the answer anywhere on the internet. And i only found one other person with the problem but there was only one reply which did not solve the problem.
I have a Mac mini running the latest software which i installed recently but it worked fine until now. I tried uninstalling the app and reinstalling it but nothing.
Please help there is no better program out there.
Re: Am i the only one with this problem? File Can't be loade
Thanks for your request, mindscape8088. Do you use XnView Classic (Windows) or XnView MP?
If I understand right, the problem occurs whenever you start XnView. And then XnView exits right away, correct?
