0.83: Export preview doesn't use the same resampler for both
Tup3x
I guess this image explains it pretty well:
So basically the export view (at least on Win 10 x64) uses different (and much worse) resampler for the preview image. Thus it's not very useful at all unless you use 1:1 zoom level.
Re: 0.83: Export preview doesn't use the same resampler for
See Issue 979 for details.
Tup3x
This problem is supposed to be fixed in XnView MP 0.84 beta 1. Could you please try and confirm the bug fix, Tup3x?
