Different NConvert versions output different filenames
Different versions of NConvert now produce different output filenames for this code:
nconvert -xall -dpi 300 -out jpeg -o "%%###.jpg" Multipage.pdf
NConvert 6.05 x32:
Multipage001
Multipage002
Multipage003
Multipage004
NConvert 6.88 x32:
Multipage001-0
Multipage001-1
Multipage001-2
Multipage001-3
Tested using Ghostscript versions 9.15 x32 and 9.20 x32.
Pierre?
Re: Different NConvert versions output different filenames
yes was changed in a previous version...
xnview wrote:yes was changed in a previous version...
Intentionally?
The current filenames are not the expected result which has caused some confusion, and are also not consistent with the documentation in the Help file. :(
Possibly a reason to do with processing multiple, multipage files??
The earlier filenames seem more desirable, the pages of a multipage file are numbered sequentially following the base filename... :D
Intentionally?
seems to be a bug :) i'll fix it
xnview wrote:seems to be a bug :) i'll fix it
Testing the new NConvert 6.92 (in the XnView 2.37 Extended/Full download) with this code:
Expected output filenames:
Multipage001
Multipage002
Multipage003
Multipage004
Actual output filenames:
001
001002
001002003
001002003004
... :wink:
I've fixed the problem with % (package updated)
xnview wrote:I've fixed the problem with % (package updated)
I'm getting 'Bad version of libformat' error message...
:( it's fixed now
xnview wrote::( it's fixed now
Still getting same error message from downloaded XnView 2.37 Extended/Full ZIP version... :wink:
now it's fixed :( Sorry about this problem...
xnview wrote:now it's fixed :( Sorry about this problem...
Thanks, NConvert 6.93 now works as expected... :D :D
As a general point, it would be better if the latest version of NConvert could always be downloaded from the NConvert download page, rather than sometimes only being available in the XnView Classic Extended/Full download... But I do appreciate the problem of maintaining so many software versions with quite frequent updates.
