Linux: Rename folders in Folders pane
mykurtaccount
Post by mykurtaccount »
Operating System: Linux, KDE 5
XnViewMP version: 0.83 (Fedora Linux 64 bits)
If I rename a folder in the folder pane, whilst it does rename the folder, the folder then becomes unbrowsable from the Folders panel.
If I right click the newly renamed folder in the Folders panel and select Explorer it is still trying to open the old folder name
