0.81 Windows: xnviewmp.exe sticky process after close
Marsu42
I know this isn't exactly the most helpful bug report, but it happens rather often and is annoying:
After closing XnViewMP (I'm currently running x64), the task is still active even though the window is gone. The task keeps consuming the same amount of cpu power (25% on my 4-core system), i.e. seems to be stuck in a loop. If "One instance of program only" is checked, of course other xnview instances refuse to open unless the stuck program is killed somehow, for example using the taskmanager.
I wonder if it's just a case of "just me", but I have this problem for quite a long time and a longer series of xnviewmp versions :-\
Re: [Windows] xnviewmp.exe sticky process after close
always? All thumbnails are built?
Marsu42
It happens maybe in 10'% of cases, and thumbnails don't seem to have anything to do with it - I open a file from the command line or explorer (i.e. single image mode), sometimes browse other files in the same folder with back/forward, and then close xnview. One possible hint is that the more busy my computer is, the more often the stuck process seems to occur, or if I close xnview very quickly after opening an image file... but's it's really hard to pin down unless debugging in which loop it's stuck.xnview wrote:always? All thumbnails are built?
so only in viewer mode?
Marsu42
I guess so since I'm using viewer mode most of the time, but I cannot completely exclude the possibility that is has never been stuck from browser mode, ever :-\ ... I'm so used to kill it from task manager by now I really don't memorize what the last mode was before quitting xnview.xnview wrote:so only in viewer mode?
Btw it's not like I'm running a completely maiden windows and just xnview for bug tracking purposes, but xnview is the only app that has this behavior on my system.
do you use 'read ahead'?
Marsu42
Yes, absolutely. I can try to disable it and see if it still hangs though, even if's tricky to tell as it occurs only so often.xnview wrote:do you use 'read ahead'?
Btw: Don't let me detain you from expanding this like "Read _ images ahead" - if there's enough memory, why not read ahead more like FastPictureViewer does?
always a running process?Marsu42 wrote:Yes, absolutely. I can try to disable it and see if it still hangs though, even if's tricky to tell as it occurs only so often.xnview wrote:do you use 'read ahead'?
Marsu42
What do you mean with "always a running process"? If it's stuck after close (i.e. XnViewMP window is gone), then yes, it's always running at 25% cpu load (4-core system).xnview wrote:always a running process?Marsu42 wrote:Yes, absolutely. I can try to disable it and see if it still hangs though, even if's tricky to tell as it occurs only so often.xnview wrote:do you use 'read ahead'?
i means without 'read ahead'?Marsu42 wrote: What do you mean with "always a running process"? If it's stuck after close (i.e. XnViewMP window is gone), then yes, it's always running at 25% cpu load (4-core system).
Marsu42
Nope, it seems without read ahead xnviewmp closes just fine. Alas, I didn't try it a 1000 times so I cannot say for certain that this is the definitive source of the problem, but seems like a very likely candidate to me.xnview wrote:i means without 'read ahead'?Marsu42 wrote: What do you mean with "always a running process"? If it's stuck after close (i.e. XnViewMP window is gone), then yes, it's always running at 25% cpu load (4-core system).
Re: 0.81 Windows: xnviewmp.exe sticky process after close
@Pierre: Is there are problem with "Read image ahead"? If yes, has this been fixed?
yes in previous version, was fixed in 0.84helmut wrote:@Pierre: Is there are problem with "Read image ahead"? If yes, has this been fixed?
O.k.xnview wrote:.. yes in previous version, was fixed in 0.84
@Marsu42: Could you please try v0.84 and confirm the bug fix?
