XnViewMP
Version 0.82 x32 (Sep 12 2016)
Libformat version 6.91
Using XnView on Linux Mint:
RELEASE=17.1
CODENAME=rebecca
EDITION="MATE 32-bit"
DESCRIPTION="Linux Mint 17.1 Rebecca"
DESKTOP=MATE
TOOLKIT=GTK
Problem: it seems to crash whenever it finds files taht it doesn't like.
Terminal output is as follows:
LOAD BITMAP </home/<user>/Bilder/Sigma SD10 -X3F/IMG07285.X3F>
ItemData :: update ==> Screeshots-Shutter
ItemData :: update ==> Screeshots-Shutter OK
RAW : 6172892 0
RAW : 2 (1)
my_error_exit...<Not a JPEG file: starts with 0x00 0x00>
ERROR : 2
AFTER WAIT
###### onChildrenChecked 9 <vlc>
###### onChildrenChecked 8 <TEST>
###### onChildrenChecked 7 <Sigma SD10 -X3F>
###### onChildrenChecked 6 <Screeshots-Shutter>
###### onChildrenChecked 5 <LinuxMint>
###### onChildrenChecked 4 <faenge-agv>
###### onChildrenChecked 3 <Crailsheim-Luftbilder>
### ThumbLoaderThread :: setFirstItemToLoad
### ThumbLoaderThread :: setFirstItemToLoad ok
RAW : 3 (0)
RAW::getThumbnail 1
RAW::getPicture
(null) has unknown CAMF type -1.
(null): "DarkShieldColRange" matrix not found!
(null): "PostPolyMatrix" matrix not found!
(null): "SaturationLevel" matrix not found!
(null): "KeepImageArea" matrix not found!
(null): "ActiveImageArea" matrix not found!
(null): "ChromaDQ" matrix not found!
(null): "ColorDQCamRGB" matrix not found!
(null): "DarkShieldTop" matrix not found!
(null): "DarkShieldBottom" matrix not found!
(null): Invalid white balance "Auto"
*** Error in `/opt/XnView/XnView': malloc(): memory corruption: 0xaf60a008 ***
Aborted
I cannot delete everything from disk... just because XnView doesn#t like it. So hopefully you can fix this.
BTW: Tried latest version as well, also some of the 0.7x series ... same behaviour.
Cheers
0.82 x32: Crashes often (because of x3f files ?)
Re: 0.82 x32: Crashes often (because of x3f files ?)
