Bug:
Program hangs/crashes when running the "Update Files From Catalog" operation on a large number of files.
To Reproduce:
Attempt to run the Update Files From Catalog operation on a large number of files (>10,000)
Specifics:
After selecting the operation, the operation starts. After several minutes, one of two things happen, seemingly based on the number of images selected to be processed:
1. The program completes the operation successfully, but then hangs for several minutes after completion. Title bar reports "Not Responding" during this time.
2. The program crashes before the operation is completed. Some files appear to have been updated successfully.
Program Hang/Crash (Update Files From Catalog)
ginkner
Re: Program Hang/Crash (Update Files From Catalog)
do you have sent the crash report?
