Conversion from DWG, DXF
jkalousek
Post by jkalousek »
Hi, I have simple question really. Compatibility list of XnConvert containts "AutoCAD DWG - dwg, dwt" but when I drag DWG file in and chose "Convert" I get error message: "...dwg 0x0x0 : not a picture".
I know that DWG is proprietary format. So is DWG support only available for some older version of the format? Or am I doing something wrong?
Also same thing is happening to me with DXF format.
Thank You.
Re: Conversion from DWG, DXF
no sorry, only XnView Classic has a third party plugin (32bits) for DWG/DXF
jkalousek
Post by jkalousek »
Ok, thank you for reply, so is it possible to do DWG, DXF command line batch conversion with XnView Classic Extended and Nconvert?
jkalousek wrote:Ok, thank you for reply, so is it possible to do DWG, DXF command line batch conversion with XnView Classic Extended and Nconvert?
with XnView Classic if you have the third party plugin (not free)
jkalousek
Post by jkalousek »
Ok, I noticed that it is in paid version, thats not a problem but I need it to run on Linux so has paid version of XnView MP same capabilities as XnView Classic in regards of formats and batch conversion from command line?
Thank you for information!
the plugin exists only for windows
