Rebuild thumbnails confusing
jadO
View->Rebuild thumbnails is confusing. What is it supposed to do? Does it rebuild the thumbnail for the selected files? Or the folder I am currently in? Or all thumbnails in the database?
Re: Rebuild thumbnails confusing
It rebuild thumbnails for selected thumbnail or current folder if no selection
jadO
Ah I see. It would be nice to have this as context menu. Then it would be clear that is will be performed on the selected item(s).xnview wrote:It rebuild thumbnails for selected thumbnail or current folder if no selection
jadO
Now when I tried to rebuild thumbnails, it did not work.
It did not change the thumbnails at all.
Only via settings->thumbnails when I delete thumbnails for a selected folder and then open that folder, the new thumbnails get generated.
the thumbnails are generated only if needed
jadO
Oh. So it is even more confusing. I think that is not a good decision. When I want to rebuild a thumbnail, XnVieMP should rebuild the thumbnail as requested.xnview wrote:the thumbnails are generated only if needed
no sorry the thumbnail is recreated.jadO wrote:Oh. So it is even more confusing. I think that is not a good decision. When I want to rebuild a thumbnail, XnVieMP should rebuild the thumbnail as requested.xnview wrote:the thumbnails are generated only if needed
how do you see that?Now when I tried to rebuild thumbnails, it did not work.
jadO
I checked that with one of those file where 4 thumbnails did not work. After switching to ffmpeg I need to recreate those to have 4 thumbs for them as well.xnview wrote:how do you see that?Now when I tried to rebuild thumbnails, it did not work.
Now when I clicked one of those and pressed rebuild, nothing happend.
it works for me
jadO
After some testing to me it seems that clicking rebuild thumbnail does not trigger the function to start.
When I select some files then click "rebuild thumbnails" then scroll up a bit, only then the thumbnailing starts.
Other triggers not working in XnView MP as well.
Ilikemyprivacy
Rebuild thumbnails isn't working on it either. It may have something to do with the other symbols. There are three...
1. A small white box in the corner: I think that's the embedded image one
2. A white I: that's an uppercase i not a lower case L
3. A white E.
Cleaning the thumbnail removes all but the small white box, and like I said, it doesn't clear up the thumbnail, and the other symbols just return as soon as I re-click on the folder or rebuild the thumbnail. Before cleaning would clean the thumbnail but it would do that by making a copy of the image as a .jp_ file.
3. A white E.
bsac
Rebuilding thumbnails DOES NOT WORK.
I select all files that are in the folder using EDIT MENU > SELECT ALL FILES then go to View Menu and select REBUILD THUMBNAILS yet all the files that are not displaying a thumbnail image remain. Are files broken and impossible to rebuild the thumbnail?
I'm not sure if it is me, but the menus and options/sub menus are hard to understand because they are not intuitive.
Is it just me?
I'm trying to fix all my family photos that do not have thumbnails. Am I using the right app to fix these files?
Is it just me?
they are finebsac wrote: Sat Aug 23, 2025 9:55 pm I'm not sure if it is me, but the menus and options/sub menus are hard to understand because they are not intuitive.
check XnViewMP - thumbnails - understanding quality/size
