Not possible to turn off 'Fullscreen>Show playbar'
obelisk
Post by obelisk »
fullscreen-show playbar
no matter what it is on next time you open
obelisk
Re: It is not possible to turn off setting
Post by obelisk »
Actually forget that, a bunch of different settings won't stick.
obelisk
Post by obelisk »
I think you need to recheck all your settings dialog. Does it apply ALL settings (not just changed stuff - I think that's how you're forgetting some) when you "OK" it?
Does it save it all to the ini right then?
Re: Not possible to turn off 'Fullscreen>Show playbar'
sorry but it works correctly, the playbar is not shown after changing it
obelisk
Post by obelisk »
Nope, most of the settings don't save. I always have to edit the ini.
obelisk wrote:Nope, most of the settings don't save. I always have to edit the ini.
There is a problem with rights in this case.
obelisk
Post by obelisk »
What should I check?
