When using XnConvert to batch resize a set of files in a folder>subfolder>file situation, is it possible to batch rename the files, with a single naming/numbering convention, in a way that respects structural integrity?
If I use Filename Image ### - then Image 001, Image 002, and Image 003 may well appear in three different folders. Each file will have a discrete name but the folder>subfolder>file structure will be disregarded.
If I use Filename Image $$$ - then Image 001, Image 002, and Image 003 will be sequential within a particular folder but the names will not be discrete. The same names without differentiation will appear in every folder.
{Directory}# or {Filename Number} will produce discrete (albeit possibly long and unwieldy) names, but not a singular naming scheme.
I guess another approach would be to ask - is there a way to load source files in a folder>subfolder>file situation in a way that respects the folder structure?
One Rename To Rule Them All
Re: One Rename To Rule Them All
do you use 'Keep folder structure'?
dvdflow
Yep, I do have 'Keep Folder Structure' Selected.
could you post a screenshot of Status window to show the problem, please?dvdflow wrote:Yep, I do have 'Keep Folder Structure' Selected.
dvdflow
ok, thanks. So you would like that output folder are sorted before to process? (All Strart 1 files, All Strat 2 files, ..)?
dvdflow
Yes, exactly. i have figured out that I can use the Krename program to rename and then Xnconvert to convert. I'm just a bit lazy and was hoping for a one program solution.xnview wrote:ok, thanks. So you would like that output folder are sorted before to process? (All Strart 1 files, All Strat 2 files, ..)?
if you sort by folder in Input tab?dvdflow wrote:Yes, exactly. i have figured out that I can use the Krename program to rename and then Xnconvert to convert. I'm just a bit lazy and was hoping for a one program solution.xnview wrote:ok, thanks. So you would like that output folder are sorted before to process? (All Strart 1 files, All Strat 2 files, ..)?
dvdflow
grow the dialog to have 'Folder' in header
dvdflow
O.K. I right clicked on the sorting options bar, disabled all the options except for folder. Now the only options shown are name and folder and the program does exactly what I want it to.
Thank You Pierre! This is so cool. I've gone from loving this program to loving it a lot.
