Can't download XnView software [Solved]
teknowledgist
Post by teknowledgist »
I can't seem to successfully download the current (Windows) version (0.8.3). Each attempt takes many minutes (on a very fast, academic connection!) which in itself isn't a big problem, but each "completed" download is a different file size and doesn't work. I've tried multiple times on multiple systems (Mac and PC).
Is this a common issue right now?
Thanks.
Re: can't download
Welcome to the forum, teknowledgist.
The main download server seems to be up & running. Could you please give download2.xnview.com a try?
teknowledgist
Re: can't download
Thanks for the reply.
I tried the main download pretty much all day yesterday and early this morning with the same results. I'm not sure what happened, but it seems to be working now. Downloads are quite fast (~12 seconds) and the checksum is consistent.
Sorry if I caused any trouble.
