Rotate crash
gelepore
Rotate crash
Post by gelepore »
Xnview crashes every time I try to custom rotate a file. As soon as I try to rotate - crash. I'm on a brand new XP box and the latest xnView. Any ideas?
Re: xnview rotate xp crash
gelepore wrote:Xnview crashes every time I try to custom rotate a file. As soon as I try to rotate - crash. I'm on a brand new XP box and the latest xnView. Any ideas?
Strange, do you use the JPEG lossless rotation? In view or in the browser?
gelepore
rotate
Post by gelepore »
Pierre,
After some more experimentation, it appears the problem only occurs on Group IV Tiff files. I get the rotate dialog, change it to an arbitrary setting, click OK, and the crash occurs. The exact tif is located at:
http://mdsa.net/megafile/msa/speccol/sc ... 43--27.tif
thanks,
Greg
Re: rotate
Greg, with the image supplied via your link the problem can be reproduced easily. I have used a Windows 98 First Edition box to reproduce, so this is not just a problem of Windows XP. :bugconfirmed:
marsh
Post by marsh »
Fixed as of v.1.74 :twisted:
Preparing for the soon expected chaos... Please Close.
marsh wrote:Fixed as of v.1.74 :twisted:
Moved to "Closed" Thank you for retesting, marsh. There might be some chaos, but I hope it won't too bad. We still have the "Date posted" which gives an indication which XnView has been used.
