How to insert a watermark with XnView MP 0.83
I'm not able to find the tool of inserting a watermark on a picture, in the size and place of the picture I wish. I'm using XnView MP 0.83 in a Mac computer, where can I find that tool? Thank you so much.
Re: How to insert a watermark with XnView MP 0.83
Thank you for registering and welcome in the XnView forum, Franpagu.
After opening an image there supposed to be "Image > Add Watermark..." menu but this functionality hasn't been in XnView MP implemented, yet (it's available in XnView Classic for Windows).
What you can do is using XnView MP's batch conversion:
1. In XnView browser select your image
2. Select "Tools > Batch convert" (or press Ctrl + U)
3. In "Actions" tab please choose "Add action > Image > Watermark".
4. Specify the watermark parameters as desired.
5. Change output filename / directory as/if desired.
6. Press "Convert"
6. Press "Convert"
