0.83 Linux: Preview pane freezes......
bakdoor
Post by bakdoor »
Linux Mint (Mate 17.2) XnViewMP 0.83
Whenever I open a file the preview pane freezes on the desktop. All controls in the pane work fine. I just can't move the whole pane around on the desktop. Image panes in all other image viewers I have work fine.
Any ideas?
Thanks
Re: 0.83 Linux: Preview pane freezes......
you start XnViewMP, move the preview pane on the desktop, and when you choose an image file you have a freeze?
bakdoor
Post by bakdoor »
xnview wrote:you start XnViewMP, move the preview pane on the desktop, and when you choose an image file you have a freeze?
I've since discovered that I can move the pane but only if I position the mouse cursor at the very top edge of the pane. (top border edge)
Not ideal, but I guess it works.
Thanks for replying.
