F2 Rename - how to add other date formats?
mrwul
Post by mrwul »
Say I want to rename files from within XnViewMP by using F2
I'd like to enter free text and XnView should then automatically add the modified date-time to the filename.
So, the sequence would be
F2
enter text (this will automatically overwrite the existing filename)
hit [Enter]
File is then renamed to what I have entered plus ddmmyyyy hhmmss - automatically (no need to select from drop down list, etc.
