I see frequent reproducible crashes when:
1. Video thumbnailing with ffmpeg
2. Create thumbnails for entire folder is set
3. While thumbnailing is in progress start some videos
XnViewMP crashes.
0.81: Frequent crashes when video thumbnailing with ffmpeg
jadO
Re: 0.81 Frequent crashes
you means 0.83?
jadO
No, I mean 0.81. As due to the frequent freezes I had to go back to 0.81 which does not have those freezes.xnview wrote:you means 0.83?
sorry but i can't fix 0.81 only 0.83
jadO
I can't use 0.83 as long as it freezes.xnview wrote:sorry but i can't fix 0.81 only 0.83
as i said, i can't reproduce your problem.jadO wrote:I can't use 0.83 as long as it freezes.xnview wrote:sorry but i can't fix 0.81 only 0.83
Do you have this freeze with MPC too?
jadO
I was not able to test that yet becuase this means I have to switch to 0.83 again.xnview wrote:Do you have this freeze with MPC too?
But as I said: I don't have those freezes with 0.81 on the VERY SAME SYSTEM. It started with 0.82, so the issues is clearly XnViewMP 0.82 and 0.83.
you can install the 2 versions on same computerjadO wrote:I was not able to test that yet becuase this means I have to switch to 0.83 again.xnview wrote:Do you have this freeze with MPC too?
