Exif mod. date shown as "date taken" in the browser
jms
Post by jms »
I have some pictures with an exif date modified of 18.8.2016 and date taken of 20.2.2016.
But in the browser, XnView shows in the tooltip 18.8. as the date taken and if I sort by exif date, it sort by that modified date and not by date taken.
Re: Exif mod. date shown as "date taken" in the browser
please send a file sample?
jms
Post by jms »
I already found your answer in http://newsgroup.xnview.com/viewtopic.p ... 75&p=46930
by xnview » Mon Mar 19, 2007 8:44 am
Ok, it's normal, the date used for sort is 'EXIF: date modified'
So it is sorting by <date modified> by design.
I was assuming it sorts by date taken.
But the mouse-over tooltip should be changed. It says the date is {Date taken} but this is wrong.
I cannot upload a sample because I'm limited to 2MB and it only makes sense if I upload the original image.
jms wrote:... So it is sorting by <date modified> by design.
Correct.
jms wrote:... But the mouse-over tooltip should be changed. It says the date is {Date taken} but this is wrong.
helmut wrote:By default, XnView 0.83 and before uses the following entry for tooltips:
"<b>{Filename}</b><br>{Modified Date} - {Date taken}<br>{Size KB} Kib"
The placeholder {Date taken} for EXIF date taken is wrong, correct is {EXIF:Date taken}. In XnView 0.84 the default is correct, when updating and using your .ini files please check in Tools » Settings | Browser | Browser whether the tooltip is set properly.
From what I can see the original "problem" is solved. Please post here if this should not be the case.
:arrow: Closed
jms
Post by jms »
When saving a picture in linux, the modification date is not updated.
Thank you for your prompt reply, jms.
jms wrote:When saving a picture in linux, the modification date is not updated.
O.k., that's a different problem. Could you please create a new bug report for it?
jms
Post by jms »
I just found the setting "tools-settings-general-file operations-keep orignal file date/time".
The default was to keep the original date.
jms wrote:I just found the setting "tools-settings-general-file operations-keep orignal file date/time".
Good that you've found the solution and thank you for posting it here, jms. :)
