0.83: Memory usage for database - limited to 3 digits
masterjp
Post by masterjp »
In the settings menue it is possible to change the maximum size for cached thumbnails and memory usage for the database engine.
You can insert values with three digits (e.g. 999 MB). If you use the arrow up switch, you will increase the value above the three digits limit.
It would be nice to insert values with 4 or 5 digits for PCs with 8 GB RAM oder higher! - Thank you!!!
