Way to minimise program in full screen using mouse
sasko1
Post by sasko1 »
Hello!
I'd like to request a way to minimise the program while in full screen view using the mouse, such as an icon on the toolbar to click, when the option to display the toolbar is enabled.
Or possibly a new mouse left-click / right-click or other settings option, if it doesn't conflict with another mouse action I need. But preferrably as an icon.
Or maybe, if it is possible of course, to have something like this:
Any of the above options will be just fine.
Thank you!
Moderators note: Request links from this Support thread: Where's "Minimize" button for minimizing program window?
sasko1
Re: Way to minimise program in full screen using mouse
Post by sasko1 »
I have another solution for this, maybe easier one. If there is no option to add minimise button, maybe just an option (opt in/opt out) for a bottom Task bar to be seen, while using full screen view. So full screen view wouldn't stretch over task bar.
Thanks
