Can't rename videofiles
Morku
Post by Morku »
I switched from XnView Classic to MP (Windows x64).
I like to use renaming photos and videos with XnView. It's no problem with photos. I go to Tools and Batch rename, I check the photofiles and rename it.
But it's impossible for videos (in my case MOV files from my DSLR), because when I try to rename, it is "in use". So every videofile I only mark in XnViewMP, is already in use and unable to rename. I also can't move the file with explorer until I uncheck in XnViewMP. I also tried to disable the preview in XnView, but sadly id did not the trick. It gets in use, when the videofile is checked.
This doesn't happen with the classic version, I can easily rename videofiles.
Would be great to fix it, until that, I have to move back.
Thank you.
