Text shadow in NConvert
felipe4334
I exported a XnConver job to Nconvert and it did export all the functions, one of them was the shadow for text therefore, everything looks weird on the NConver job, is there a way that the Nconver do the same job as XnConver? Thanks.
Could you please post the code you are using, and if possible show the different results produced by XnConvert and NConvert?felipe4334 wrote:I exported a XnConvert job to NConvert and it did export all the functions, one of them was the shadow for text therefore, everything looks weird on the NConvert job, is there a way that the Nconvert do the same job as XnConvert?
I'm not familiar with the shadow effect, if it is supported in NConvert, but someone else may be able to help...
felipe4334
Re: Text shadow in NConvert
cday wrote:Could you please post the code you are using, and if possible show the different results produced by XnConvert and NConvert?felipe4334 wrote:I exported a XnConvert job to NConvert and it did export all the functions, one of them was the shadow for text therefore, everything looks weird on the NConvert job, is there a way that the Nconvert do the same job as XnConvert?
nconvert.exe -o "OutPutName.jpg" -text_font ADAM.CGPRO 111 -text_color 111 255 255 -text_back 255 0 0 -text_flag center -text_pos 0 0 -text_rotation 0 -text "nameOfPlayerYoutubeEdited" -text_font ADAM.CGPRO 44 -text_color 44 255 0 -text_back 0 0 0 -text_flag bottom-center -text_pos 0 -127 -text_rotation 0 -text "KDAOfPlayer" -text_font ADAM.CGPRO 52 -text_color 52 249 249 -text_back 249 0 0 -text_flag bottom-center -text_pos 0 -10 -text_rotation 0 -text "League Of Legends" -wmopacity 100 -wmfile "D:\Dropbox\Projects\Bot\Record Games\Lolking\replays\champions\400x400.png" -wmflag top-left -wmopacity 100 -wmfile "D:\Dropbox\Projects\Bot\Record Games\Lolking\replays\champions\challenger_1.png" -wmflag top-left Olaf_Splash_Centered_0.jpghttp://imgur.com/a/mH6Sd
NConver
http://imgur.com/a/tChg7
Thanks for helping.
O.K. something not right there:
Can anyone see the problem
[Please note the spellings of XnConvert and NConvert
felipe4334
That's what I mean, I have text shadow on XnConvert but not on the NConver code I don't know how or why.cday wrote:O.K. something not right there:
But not a text shadow issue and no text shadow term in your code...
[Please note the spellings of XnConvert and NConvert]
felipe4334
Can anybody help
- Forum Librarian
AFAIK, adding a drop-shadow effect to text is not supported by nConvert.
[color=green]nconvert.exe -help[/color] wrote:Code: Select all
-text string : Add a text -text_font name size : Font name and size -text_color r g b : Text color -text_back r g b : Text background color -text_flag pos : Position of text top-left, top-center, top-right center-left, center, center-right bottom-left, bottom-center, bottom-right -text_pos x y : Position or offset -text_rotation degrees : Rotation
felipe4334
XnTriq wrote:AFAIK, adding a drop-shadow effect to text is not supported by nConvert.
that explains a lot, thanks
NConvert doesn't support text shadow
felipe4334
Is there any way of working around it, example multiple layers of text?xnview wrote:NConvert doesn't support text shadow
Possibly by writing the text twice, the second slightly displaced and lighter?? But I think you would be lucky to get a satisfactory result, although you could always try...felipe4334 wrote:Is there any way of working around it, example multiple layers of text?xnview wrote:NConvert doesn't support text shadow
Otherwise probably using ImageMagick which supports an amazing number of imaging functions...
felipe4334
Thanks ill try it out.cday wrote:Possibly by writing the text twice, the second slightly displaced and lighter?? But I think you would be lucky to get a satisfactory result, although you could always try...felipe4334 wrote:Is there any way of working around it, example multiple layers of text?xnview wrote:NConvert doesn't support text shadow
I think with NConvert, if you apply the shadow before the foreground text it might produce the result you want, but the only way to know for sure is to try it...
