Installing XnView on TS2012R2
nls4ever
How can I configure that xnview will open without configure wizard for multiple users ?
Re: Installing XnView on TS2012R2
you can configure it on a computer, and use the xnview.ini on multiple users
nls4ever
what is the location of the xnview.ini
i'm using roaming profile
Are you using XnView Classic or XnView MP?nls4ever wrote:what is the location of the xnview.ini
If you're actually using XnView MP, the xnview.ini location can be opened using:
Tools > Settings... > Integration > Paths -- Open Config Files Location
If you're using XnView Classic, the support section you've posted in, you may find Tools > Options > System integration -- Integration helpful, although it doesn't provide a direct way to open the xnview.ini location, but a Google search for your version of Windows may point you to the likely Roaming location.
cday gave helpful information, already. Perhaps this can also be useful:
In XnView Classic and XnView MP, the location of the .ini file is displayed in the About dialog.
XnView Classic: Info > About XnView...
XnView MP: Help > About
Please note that the path may not be fully displayed but by selecting it using the mouse you can select the full path.
nls4ever
thanks, but i'm still confusing. which setting file holds the settings of the file extension ?
when i switch terminal with the same roaming profile xnview doesn't remmber that he is the defualt app for jpg, tif....
