Focus on selected image in Finder (macOS)
SuBWaReZ
Post by SuBWaReZ »
One suggestion for the option that allow to open the selected image in the Finder (in the right clic menu), the focus is on the folder that contains the image but it could be better to focus on the file itself.
For instance, in several tools likes Picasa, DxO Optics Pro and Capture One the equivalent option select the file so it should be possible to do :)
Best regards,
Mickaël
