Requirements of icon file for toolbar
sibojan
Post by sibojan »
The command I would add to the toolbar has no default icon. To make a customized one, is there any specific requirement for the format ? like the file size, resolution, depth of color?
Thank you,
Re: Requirements of icon file for toolbar
You can use a 24x24 icon in .ico format.
