Multiple Custom Selections
JohnFredC
Post by JohnFredC »
I am putting together a software manual illustrated with screen captures of some software. The manual will show both the full screen capture plus several "zoom-in" clips from the screen captures...
For aesthetic design purposes, I am standardizing the sizes of the "zoom-in" clips to 39x39, 142x68, etc, for a total of about 5 standard sizes.
XnView only supports 1 "custom" selection rectangle size.
It would help my productivity enormously if I could save many Custom selection sizes. The default ones do not meet my needs.
John
Re: Multiple Custom Selections
JohnFredC wrote:I am putting together a software manual illustrated with screen captures of some software. The manual will show both the full screen capture plus several "zoom-in" clips from the screen captures...
Ok, thanks for your suggestion.
