Can't set file association on Windows 10
EMLVIRUS
Post by EMLVIRUS »
When I run Xnview 2.39 as admin right, I can't set file association on the option windows as all buttons greyed out.
Re: Can't set file association on Windows 10
EMLVIRUS wrote:When I run Xnview 2.39 as admin right, I can't set file association on the option windows as all buttons greyed out.
Have you installed XnView using the zip archive or the setup?
EMLVIRUS
Post by EMLVIRUS »
With the extended setup
the 'windows file associations' is greyed?
EMLVIRUS
Post by EMLVIRUS »
xnview wrote:the 'windows file associations' is greyed?
Only that one is clickable, reacting as a system informing that If you are change default application, go to "setting""system""default apps". But that way can be so awkward to be used and you can only find little file types in control panel
starting vista, this is the only solution, but all file extension are not added by default
