0.84b1: Draw tool: Effects change position of text shadow
XnView 0.84 beta1
When changing the "Blur" value of the text shadow or using/unusing "Outline" , the position of the shadow changes.
Instead, the position of the shadow should remain unchanged when changing the effects and only change when changing the offset values.
Re: 0.84b1: Draw tool: Effects change position of text shado
0.84 b2: Problem NOT fixed: When changing "Blur" or the size of the outline the position of the shadow still changes.
helmut wrote:0.84 b2: Problem NOT fixed: When changing "Blur" or the size of the contour the position of the shadow still changes.
i'm not able to reproduce...
From what I can see the problem only occurs if you activate/deactivate outline.
will be fixed in beta 3
Not fixed in 0.84 beta3:
When switching "Outline" on/off (Size: 1.2), the position of the complete text changes. (This might be a different problem but very related).
helmut wrote:Not fixed in 0.84 beta3:
when drawing outline, i don't use same function to draw the text, so i don't know how to fix it
Could you perhaps always use the same function with parameter "outline=0"?
helmut wrote: Could you perhaps always use the same function with parameter "outline=0"?
this function is very slow so it's not good
O.k.. The function is slow regardless what the outline is set to, right?
xnview wrote:this function is very slow so it's not good
helmut wrote:O.k.. The function is slow regardless what the outline is set to, right?
yes
yes
O.k., so for now let's leave it the way it is. Closed.
