Linux: provide AppImages
djcj
Post by djcj »
As an alternative to .deb and .rpm packages, could you also provide AppImages?
From https://github.com/probonopd/AppImageKit/wiki:
What is an AppImage?
An AppImage is a downloadable file for Linux that contains an application and everything the application needs to run (e.g., libraries, icons, fonts, translations, etc.) that cannot be reasonably expected to be part of each target system.
It's kinda like a .App on OSX, and it works surprisingly well. It's a binary file with a compressed filesystem image attached, which will be mounted on start.
To create an AppImage you'll need to save this YAML file, ie. as XnViewMP.yml:
app: XnViewMP
ingredients:
  dist: precise
  packages:
    - libasound2
    - libatk1.0-0
    - libc6
    - libcairo2
    - libcups2
    - libfontconfig1
    - libfreetype6
    - libgcc1
    - libgdk-pixbuf2.0-0
    - libgl1-mesa-glx
    - libglib2.0-0
    - libgstreamer0.10-0
    - libgstreamer-plugins-base0.10-0
    - libgtk2.0-0
    - libice6
    - libpango-1.0-0
    - libpangocairo-1.0-0
    - libpangoft2-1.0-0
    - libpulse0
    - libsm6
    - libsqlite3-0
    - libstdc++6
    - libx11-6
    - libx11-xcb1
    - libxcb1
    - libxcomposite1
    - libxext6
    - libxi6
    - libxml2
    - libxrender1
    - libxslt1.1
    - zlib1g
  sources:
    - deb http://archive.ubuntu.com/ubuntu/ precise main restricted universe
    - deb http://archive.ubuntu.com/ubuntu/ precise-updates main restricted universe
    - deb http://archive.ubuntu.com/ubuntu/ precise-security main restricted universe
  script:
    - VERSION=$(wget -q -O- http://www.xnview.com/xnviewmp_update.txt | sed -n -e 's/^version=//p' | sed -e 's/\r//g')
    - wget -c http://download.xnview.com/old_versions/XnViewMP-$(echo $VERSION | tr -d '.')-linux-x64.tgz
    - wget -c http://archive.ubuntu.com/ubuntu/pool/main/c/chrpath/chrpath_0.13-2build2_amd64.deb -O chrpath.deb
    - echo $VERSION > VERSION
script:
  - dpkg -x ../chrpath.deb ../chrpath
  - tar xf ../XnViewMP-*-linux-x64.tgz
  - ../chrpath/usr/bin/chrpath -d XnView/XnView
  - find XnView/* -type f -name *.so* -exec ../chrpath/usr/bin/chrpath -d '{}' \;
  - mkdir -p usr/bin usr/share/icons/hicolor/64x64/apps
  - mv XnView/ usr/
  - cat > usr/bin/xnviewmp <<\EOF
  - #!/bin/sh
  - usr="$(pwd)"
  - export GST_PLUGIN_PATH="$usr/lib/x86_64-linux-gnu/gstreamer-0.10"
  - export GST_PLUGIN_SCANNER="$usr/lib/x86_64-linux-gnu/gstreamer0.10/gstreamer-0.10/gst-plugin-scanner"
  - export LD_LIBRARY_PATH="$usr/XnView/lib:$usr/XnView/Plugins:$LD_LIBRARY_PATH"
  - export QT_PLUGIN_PATH="$usr/XnView/lib:$QT_PLUGIN_PATH"
  - "$usr/XnView/XnView" "$@"
  - EOF
  - chmod a+x usr/bin/xnviewmp
  - cat > xnviewmp.desktop <<\EOF
  - [Desktop Entry]
  - Type=Application
  - Name=XnView MP
  - Comment=Graphic viewer, browser, converter
  - Exec=xnviewmp %U
  - Terminal=false
  - Icon=xnviewmp
  - Categories=Graphics;
  - StartupNotify=true
  - MimeType=image/bmp;image/gif;image/jpeg;image/png;image/tiff;image/x-tga;image/x-pcx;image/jp2;
  - EOF
  - cp ./usr/XnView/xnview.png xnviewmp.png
  - cp xnviewmp.png ./usr/share/icons/hicolor/64x64/apps/
Make sure that FUSE (filesystem in userspace) is available, otherwise the final step of creating the AppImage will fail:
sudo apt-get install fuse
sudo modprobe fuse
user="$(whoami)"
sudo usermod -a -G fuse $user
Then run this in shell:
wget -O Recipe https://raw.githubusercontent.com/probonopd/AppImages/master/recipes/meta/Recipe
bash Recipe XnViewMP.yml
To figure out the dependencies you need to add to the packages list of the YAML file you can run this shell script inside XnView's directory:
#!/bin/sh
echo "wait a few seconds..."
alldeps="$( (find ./* -type f -exec readelf -d '{}' 2>/dev/null \;) | grep 'NEEDED' | cut -d '[' -f2 | tr -d ']' | sort | uniq )"
for f in $alldeps; do
  if [ "x$(find ./* -name $f)" = "x" ]; then
    deps="$deps $f"
  fi
done
for f in $deps; do
  if [ "$f" = "libGL.so.1" ]; then
    pkgs="$pkgs libgl1-mesa-glx"
  else
    pkgs="$pkgs $(dpkg -S $f | grep "amd64" | grep "\/$f\$" | head -n1 | cut -d: -f1)"
  fi
done
echo ""
echo "dependencies are:"
echo "$pkgs" | tr ' ' '\n' | sort | uniq
A few notes:
  • since AppImages are already compressed, it's recommended to not put them into a zip or tar archive, but instead provide downloads to the raw .AppImage files
  • the older the system the binaries were build on, and the older the distribution set in the YAML file, the more downwards compatible are those AppImages
  • the AppImage created on my system has a size of 59 MiB, only 10 MiB bigger than the original tarball
  • the current build system only supports 64 bit x86 architecture (x86-64, amd64)
Re: Linux: provide AppImages
i've added a 0.84 x64 Appimage link
CreativeWorld
Post by CreativeWorld »
I would also suggest to implement a snap distribution like Inkscape does:
http://snapcraft.io/
djcj
Post by djcj »
xnview wrote:i've added a 0.84 x64 Appimage link
Great. Works well for me.
Here's an updated recipe for XnView MP 0.84:
app: XnViewMP
ingredients:
  dist: precise
  packages:
    - libasound2
    - libatk1.0-0
    - libcairo2
    - libcups2
    - libdbus-1-3
    - libegl1-mesa
    - libfontconfig1
    - libfreetype6
    - libgl1-mesa-glx
    - libglib2.0-0
    - libgtk2.0-0
    - libice6
    - libjasper1
    - libpango-1.0-0
    - libpangoft2-1.0-0
    - libpulse0
    - libsm6
    - libsqlite3-0
    - libx11-6
    - libx11-xcb1
    - libxcb1
    - libxext6
    - libxi6
    - libxrender1
    - zlib1g
  sources:
  script:
    - tar xf XnViewMP-*-linux-x64.tgz
    - rm -f XnView/XnView.desktop XnView/XnView.desktop~
    - dpkg -x chrpath.deb chrpath && rm chrpath.deb
script:
  - mv ../XnView/ usr/
  - ../chrpath/usr/bin/chrpath -d usr/XnView/XnView
  - find usr/XnView/* -type f -name *.so* -exec ../chrpath/usr/bin/chrpath -d '{}' \;
  - #!/bin/sh
  - usr="$(pwd)"
  - EOF
  - [Desktop Entry]
  - Type=Application
  - Name=XnView MP
  - Exec=xnviewmp
  - Terminal=false
  - Icon=xnviewmp
  - EOF
