0.84b1: XnView after filename in titlebar [0989]
Feature works great! But you might want to add a space between the hyphen and XnView MP. If this stylization was intended, then no worries, just wanted to point it out!
Re: 0.84b1: XnView after filename in titlebar [0989]
+1 Adding a space character after the hyphen makes sense.
Important bit is that this whole suffix " - XnView MP 0.84 beta 1" is no longer visible in the final release.
