Some improvements for cut/copy/paste file operations:
1) Selecting files and cutting (Ctrl+X), should somehow indicate that the files will be removed from source location after paste. Windows does this by making file icons semi-transparent after selecting Cut. XnView should have a similar visual marker as well for a possibly destructive operation.
2) A label/indicator on the files in the clipboard (after Cut/Copy) ready to be pasted. Number of files and total size would be nice.
3) Advanced paste/replace dialog. Showing per-file overwrite options.
[XnViewMP 0.83 x64, Windows]
Cut, Copy, Paste file improvements
