0.84b2: Draw tool: Lines with length=0
0.84 beta2
A minor issue:
In the Draw tool, it is currently possible to insert lines with length = 0. If you don't look right which mode you are in you and you click onto the image such a line (=small rectangle) is drawn. I think lines with length=0 should be avoided.
EDIT: Same applies for rectangles and circles.
Re: 0.84b2: Draw tool: Lines with length=0
0.84 beta 3:
Fixed for lines, but not for rectangles and circles.
a rectangle with same corner is not kept
xnview wrote:a rectangle with same corner is not kept
Good. What I found is when inserting a rectangle by just clicking (and not dragging) the rectangle seems not to have the same corners. Only when dragging and you can resize it so that it has the same corners.
Not fixed in beta 4:
When inserting a rectangle or circles, the rectangles/circles have size 1 x 1 even though you didn't drag the mouse. As a consequence you insert lots of small rectangles by clicking around without noticing.
helmut wrote:Not fixed in beta 4:
ok
Fixed in 0.84 final. -> Closed
