Data pane (Tree pane) collapsible to tabs only
tboy
Post by tboy »
Data pane (Tree pane) can not collapse to tabs only.
Re: Data pane (Tree pane) collapsible to tabs only
tboy wrote:Data pane (Tree pane) can not collapse to tabs only.
What do you mean by this, tboy?
tboy
Post by tboy »
I have DataPane with 3 tabs
Menu >DataPane > Folders, Favorites, Categories Filter+ Show and Vertical Tabs checked
next to the right side in my layout is Thumbnails pane.
Try to drag divider between data pane and thumbnail pane to the left side until you hide it and see only tabs > NOT POSSIBLE.
Apart of this - will be good double click on tabs or empty space around tabs to act as show/hide DataPane
or better say Collaps to Tabs/Restore
leaving only tabs visible or restore last state/width of Data Pane.
