Tool -- options -- System integration -- add "browse with" XnView to context menu
This option is checked all the time. It will restore to checked status after XnView restarts with manually unchecked box.
Can not change "add browse with XnView to context menu"
sibojan
sibojan
Re: Can not change "add browse with XnView to context menu"
Still not working with admin mode.
windows 10?sibojan wrote:Still not working with admin mode.
sibojan
and you have always the 'browse with XnView' in your context menu?sibojan wrote:win 7
sibojan
Do you know editing Windows registry?sibojan wrote:Yes
sibojan
I know that workaround. But it should not be a problem with Xnview.
